Plasma cutters what do you have?
03ramit1
Glendale Az
Looking at getting a hypertherm powermax65. To run on a 5X10 CNC table. And was wondering what everyone else has.
Just got the harbor freight unit. Happy so far. Cuts 1/2" nicely. Tried 3/4, too slow. Sheet metal is like butter. Bought the 2 year warranty.
I,ll post some pics of making use of it doing a frame transplant for my Demon clone project.
I have a Miller. My kid says if it aint blue give it the shoe.
That's all I have ever used, until a deal on a thermal arc came up that was just way too good to pass up. And it will run circles arround any miller I ever touched. ( probably because the TA is brand new and the millers have all been 70's era machines)
My buddy has a miller plasma and it's nice, i would not hesitate getting one for use as a hand cutter. But it will not work on a CNC plasma cutting machine. Because it's a high frequency start machine, and it will destroy the computer.
Boy, I sure wasn't impressed. I incorrectly reasoned that I would not be cutting much thicker material, and the HF gun is junk, tips are thin.
I was thinking of buying a different gun when I ran into a Thermo Dynamics in good shape used for not much more than I paid for the HF
That Thermo Dynamics is a factor of 10 above the HF, and the gun is so obviously better made than the HF, that it's a joke.
Frankly, I'd look around for a used name brand over a new HF, if you can't afford a new one.
I have a Longevity cutter and have been VERY happy so far. Also have a Longevity MIG and TIG. No complaints so far out of any of my machines.
I will share my thoughts on this. I was a Blue guy at work and bought us a Miller. It gave me a lot of trouble including the mother board and lead. I don't know if I just got a dud, but it is fine now. Kids are using it, so things happen if you catch my drift. Miller welders are top notch. Plasma's are a sideline and I think they outsource some of it-not sure though.
The guy at the local welding store and I went rounds for about 6 months regarding brands etc. He said basically that there are two good companies. Hypertherm and Thermal Dynamics. Both are from New Hampshire as I recall, although I think that TD does some outsourcing.
The gist of it that I walked away with after obsessing for months was that that Hypertherm had a few nicer qualities and may be slightly better made. But, the TD had a little more punch and tended to be about $100-200 cheaper.
I bought the TD machine and am happy. It was around $900 and consumables are reasonable.
This is just my experience. I did a lot of research and I think alot of machines will do the job. Being from a 4x4 background we are always welding and cutting alot. I wanted to get a good machine so that I could use it for hours. We shall see what happens in the long term.
FWIW-ROB
Hell yes! That's awesome, I'm kind of partial though, there built right down the road from me. I have a Miller Spectrum, and I love it! There are alot of nice unit's out there, just depends on what your need's are.
Yeah the TD is a great unit. But the HT offers fine cut consumables and better support than TD does. And running a machine torch on a CNC table settings are alot more critical than hand cutting. The powermax 65 will pierce 5/8 and edge start 3/4 in a CNC setting the TD A80 is about the same. I have been doing alot if searching, and it seems for my application the HT is just a little better. As a hand torch though I would say they are equal.
For CNC I'm clueless. For my persenal use I bought a unit from Eastwood. Nice unit for the money. $600 plus consumables are less thn $30 for 10 sets cups and tips. either 110 or 220. I use 220
Don't be. Basically if you want to cut 1/4in you need to locate a machine tha will do 1/2 by hand. Its a loose of thumb, because of the controlled movement and speed, the power has to be there. Any plasma can go on a CNC machine, but high freq will screw with the PC. (unless you spend way too much time shielding it)
I love my blue machines, but when it comes to plasmas, I like the Hypertherms...best bang for your buck in my opinion. Excellent machines.
Not sure which one you had. Their prior model was junk. The torch on this unit is made by Trafimet - same as many of the US brands. Keep in mind that US brands use Chinese internals.
I did my research on this unit, the experience with it has been good. I have a friend who is certified in all kinds of welding and has experience with many plasma cutters. He tried it and he rated its performance good. It's rated for 1/2" cut and meets that standard. Many HF tools are indeed junk, but not all.
The 4x8 plasma table i have at work runs a powermax45. I have cut up to a 3/8 thick plate with a pierce start. It works great and the book's specs are on point. I am buying the powermax65 for my cnc plasma at home. Head over to plasma spider for all the info you want on the powermax line.
