Rice Nuker
Burn tires daily
Bought the only source of zinc I could find in my area and I am not even sure it is zinc. Claims it is.
http://www.lowes.com/pd_215441-1357...serSearch=zinc+anode&productId=3093111&rpp=48
Built a basic rig, mixed up a solution:
4.5 liters water
300 grams Epsom salts
100 grams zinc sulfate
200ml of white vinegar
1/3 bottle of corn syrup
Except I just mixed 50/50 vinegar and water and did not have the zinc sulphate.
First ran it off a battery charger but amperage appeared to be 5 amps at 6 volts so I switched over to a couple batteries to drop the amps and volts down. I still think I was running at high amps, showing about 1.7. Appeared to be plating slowly to not at all so I left it run about 9 hours. This is what I got. Now I am going to more carefully mix the mix and run one part at a time to see what happens. I think the shadows are from parts "hiding" each other from the zinc anodes.
4.5 liters water
