Do any of you guys have some suggestions. On Thanksgiving day My dad, nephew and me put a Comp cams 292H in my 340 and also added a LD340 intake. Now the motor won't stop popping. It sounds like M-80's going off in my exhaust. I have adjusted timing like crazy, put in new spark plugs, Checked the gap on the reluctor in the dist., checked my carb for trash. readjusted the air idle screw's, and checked the float level, checked all of the rockers and push rods. All valves appear to be opening flawlessly. I know for a fact that the cam timing is spot on " long story." Any way If you guys can help I would greatly appreciate it.
Motor specs are:
71 340 .060
10.5:1 comp.
J-heads 1.88 valves
Comp cams 292H .501 lift
LD340 Intake
Holley 650 DP
67 primary jets
Can't remember squirter size I think it is 27
Electronic ign.
Hooker Headers.
I will try to get a video loaded so you guy's can hear what I am talkin about.
Motor specs are:
71 340 .060
10.5:1 comp.
J-heads 1.88 valves
LD340 Intake
Holley 650 DP
67 primary jets
Electronic ign.
Hooker Headers.
