I've got a Foredom but the little drill chuck won't take a 1/4" tool. Time for a new hand piece.
Just make sure you get the 44T
Thanks. At least trying.Looks like you’re going after it pretty good!!![]()
I’ve hit water in the area where that red arrow is.
A little more towards the bowl and the floor.
HereGot hold of a 587 casting and cut it up. Made a template for the short side turn to be sure not going too far.
The rod ends under my thumb along with the macined surface to get the same distance on all turns.
Don´t know if the angle is wrong. It´s up to you pros to decide.
Some material is gonna go when the throat is cut for 1,94" valve so there will be a more steaper angle towards the end
View attachment 1715533726 View attachment 1715533727 View attachment 1715533728
The cut is about ,100" deep
I have taken some on the hump.I’m not sure how much flow you’re going after, but you can leave that hump in the corner mostly untouched and still end up in the mid-250’s.
If you use 11/32 valve guides where do you buy it ?
@PRH
@MOPAROFFICIAL
@'63GT
If you use 11/32 valve guides where do you buy it ? Part nr. ? I assume I need manganese bronze
Have found at Competitionproducts for Chevy SB. Do they fit ? ,502 OD but have no length yet.
My machine shop ordered from Summit but they were back ordered and have been for four weeks. They couldn´t wait for them though they had other things ordered that they wanted asap
Doing good so far.So.. Done some testing to get a feel for it.
Started to mill down the guides a 1/4"
Still waiting for new valves and guides so this is not the finished "boss"??
View attachment 1715531303 View attachment 1715531304 View attachment 1715531305 View attachment 1715531306 View attachment 1715531307
It´s gonna be a streeter. No recordsFor the material a lot of it depends on what you are doing and level of parts.
Iron guide wears the stem faster than the other way around. Bronze wears faster than the valve, though if you use a really nice valve with stems like glass they do better. Drag? Street? Land speed record?
Use the one you feel is gonna live up to your expectation. What valves are you using again?
Manganese .502 x 11/32 isn’t really a “Chevy” guide....... it’s a universal guide.
Just figure out what you need for length and get something close in length, but slightly longer.
They are trimmed for the correct length after installation.
Any decent machine shop should stock 11/32 x .500 guides in bronze and cast iron.
It’s a simple machine operation to install the new guides and cut them for seals.
ThanksDoing good so far.
Closed: 110 @ 1.800", Open: 340 @ 1.150", 1.160" Coil Bind
I don´t know. Tell me
