Post mini tub tire combos?
Joe68dart
Member
Victoria
Hey everybody. I am getting my 68 dart mini tubbed over the winter and have picked up some 15x10 cragars and 295/55/15 mt et street tires for the back. I got 15x6 for the front but wondering about sizing. I was thinking 195/65-15. Any got any pics??? Or any other combos? Looking for visual references. Thanks!!
325/50/15on 10 inch wheels with 4 1/2 inches back spacing fronts are 6 in M/T skinnies on 4 inch wheels with 1 3/4 back spacing.
You can do the mini tub yourself. It is really not difficult, it's just takes time.
Rear: 15x10 wheel with 325/50/15 MT radials
Front: 15x4 wheel with 165/70?/15
Nice pics! Thanks guys. To go that big are you guys using coil overs? I would do tub job my self but I just don't have the room in my garage. Car barley fits. And it's not sonething to do in the winter outside in Canada.
325/50-15 et streets on a 12" rim. 325's are 14" wide on the 12" wheel. If you want the car low i would suggest removing the outer house on the wheel tubs if you want a wide wheel that not inward of the quarter.
That looks awesome. How did you go about removing the outer wheelhouse part?
Just cut it out with an air saw, used some poster board to make a template and welded it to the tub. It's just seam sealed to the inside of the quarter, some guys epoxy or bond them but i don't like the idea of it pulling on the quarter if something his the tub hard enough.
Very cool. Thanks. What did you do along the wheel well lip? Did you leave a Part of the wheelhouse for strength?
325/50/15 on a 12" Rim. They are the M&H Racemater and the only 325 out there that would fit on a 12" Rim. I think these things hook so much better than the BFG Drag Radials that I had before.
so with all of these wheel tubs are they all stock width A body axles or did you harrow the housings? also im trying to lower my 65 signet and would like your guys opinion on the correct way to achieve this. i do know that you can adjust the torsions in the front but what is the best for the rear? im trying to lower the car about 4 inch
315/60/15 15x12 with 8" backspace
stock width rear end
15X10 with 3.5" backspace, rear narrowed 4" each side
this is a clean looking dart!
if anyone is interested I have the same wheels as these for sale. there 15x12 7.5" bs and 15x4 for the front 5x4' Bolt pattern
There also custom made from centerline in the SMALL bolt pattern, so no need to change bolt pattern to large if you don't want too. I only used them for a couple runs on the street when I was first getting the car together and decided I wanted to go with a black wheel instead pm me
I have 295 50 15 on the rear of 67 dart
stock axle housing custom 10" steelies with dog dish caps with 7 1/4 backspace
on the front i think they are too small for my liking but they are 185 55 15
but i want to switch them to a 25 or 26 inch tall tire
At moment cant find photo on my phone or computer
28"x12"x15" rear M/T, sportsman S/R, on 15"x10" ralley wheels with 5-1/2" offset.
26"x6"x15" front M/T sportsman S/R, on 15"x6" ralley wheels.
rear end shortened 3" each side.
springs moved in under frame rails.
Mini tub.
This combo leaves lots of room inside for larger tires if wanted.
I have 1" clearance to the outer fender and 1-1/2" to frame rail and inside wheel tub.
Sorry can't find side shot picture.
Nice thanks everybody lots of great info. I'm gunna start with the 295/55/15 I got but next set of tires maybe try to step up to the 325's. Thinkin about the 26-7.5 mickeys for the front
