Post your 13 sec combos
I would post the time slip from Fremont Drag Strip (in 1976, but the fire in Paradise Ca took it, along with all my pics and flash drives.
The first one: 1968 Dart GTS 340, Automatic (old school shift kit, stock converter)
Short block....Pure stock 1968 340 with 70k miles (not rebuilt)
Heads .......Pure stock 2.02s with a performance 3 angle valve job, milled .020.
Exhaust.....Pure stock cast iron manifolds, including mufflers and the under the bumper tips
Camshaft.....Pure stock, never out of the car
Carburetor....Carter AVS (from a 440, I cheated). Smaller metering rods, larger pump squirter. A few more mods (that was fun!)
Intake.....Stock 1968 cast iron
Distributor....Stock single point. Lighter springs, shorter advance
Rear.......3:91 Sure Grip
Tires ......G70-14 bias plies
13.75 @ 99.something (there was VHT on the starting line that night). 13.80s the rest of the time (no slicks, ever)
I sometimes used this GTS as a tow car for my '69 Swinger 340
Man, I just loved that cool, dense Bay Area air!
The second one in the 13s.
1973 Duster 340, Automatic (Cheap shift kit plate, no other mods)
Factory black, black buckets + console, A/C, factory cruise from an Aspen, factory steel roll-back sunroof (black vinyl, just like the full vinyl top), fold down rear seat (Convertriple?)
Short block....Pure stock 1973 (8.5 compression, 80k original miles)
Heads .......Pure stock 1.94s with a performance 3 angle valve job, milled .020.
Carburetor....Original Carter TQ, Smaller metering rods, larger pump short, + a few more mods. Still knocked down 20mpg on a 1200 miler (at 55....sigh)
Intake.....Stock 1973 cast iron. Crossover blocked
Exhaust....1969 Dart 340 cast iron. Stock mufflers and chrome tips
Rear.......3:21(?) open
Tires ......G60-14 Radial T/As
13.92 @ 100..something . 15.0s in pure stock trim
I sometimes used this Duster as a tow car for my '69 Swinger 340
70 Barracuda Gran Coupe 'vert. Untouched short block. Heads only had a valve lap and springs installed. Hughes Whiplash cam and springs. Cheap roller chain. Stock valvetrain. Headman headers. Performer RPM. 750 DP. Stock electronic ignition. 2000 convertor. Stock 727 with light valve body mod. 4.11 gear. Et Streets approx. 28x10.5. Best ET with 3000 ft DA(1350 elevation). 13.46 at 99 mph.
It is amazing how quick some of you guys have run on fairly stock combos. Back in 1979, I had a 1978 Plymouth Volare Super Coupe with the E58 Police Pursuit 360. Stock T-quad, Hooker headers,
and street radials. I think the gear was maybe a 3.21, auto trans. Best I ever ran was a 16.02, at Gainsville Raceway in Florida.
I mean, can I post my '80 D150 long bed here in the 13 second section ???? Technically, our track was only running 1/8 mile the day I took it, so I cannot post an actual "13.xx" slip. BUT, I did run 8.27 @ 82.5 mph in the 1/8, so that would be something like a 13.10 in the 1/4 ?? ...
1980 D150 Long Bed
  • 198,*** miles 5.9 from a 2000 Ram, bottom end untouched
  • reman heads (gave 300 for the pair loaded)
  • Oregon Re-grind cam (218/224 @ 050)
  • Hughes Spring Kit
  • Speedmaster intake w/750 DP
  • Hedman headers
  • Hughes "over the counter" converter
  • untouched 727
  • 4.30 gears w/28" drag radials
1980 D150 Long Bed
  • Hughes Spring Kit
  • Hedman headers
  • untouched 727
Totally awesome but honestly I'm more concerned how your health is right now which this is a good indication!..
Guess I can "officially" post the truck in here.... for now. Next time out I'll be posting in the 12 second combo thread :)
1980 Dodge D150 long bed. 360, 727, 4.3 gear.
Went 13.08, 1.82 60 ft, 8.23 1/8
I was "ok" with that being it's first 1/4 mile pass.
Details on build are in post 80.
1969 Dart GT
Short block- Junkyard 5.9 Magnum, Kevko oil pan/pickup
Heads- Stock with Hughes 1199 spring kit
Camshaft- 1634 Oregon Regrind, Rollmaster timing chain
Fuel- Holley 750DP, Carter high flow (Hughes cam snout extension), 3/8 line
Intake- Ede air gap
Exhaust- D453 headers 2 1/2" H pipe Ultraflow welded
Distributor- Accel 59301 17 initial 32 total
Rear- 8 3/4 742 3.23's
Tires- 26x9.50-15 Hoosier QTP
Transmission- 727 3000 stall, TF2 shift kit, B&M Deep pan
Cooling- Champion 22" Clutch fan/shroud
13.0X? 1/8 mile to 1/4 conversion.
Drove to the track with slicks in the trunk.
1969 Dart GT
Intake- Ede air gap
With 3.23s! Very nice!
74 Duster
Stock bottom end 360 Magnum with aluminum Speedmaster heads
Comp XR274HR-10 Cam
Edelbrock Torker 2 intake
Quick fuel 750 Double pumper
A500 overdrive auto, stock converter
4.30 geared 8-3/4 rear
275-60-15 Nitto Drag radial
Never weighed the car but it's a full option street car with AC and cruise.
13.36@104.24
I'm confident I can tune it into the 12s. And yes, a better converter will help. This was the first time out with the new motor. Previous best was a 15.35 so needless to say I was excited!
74 Duster
Comp XR274HR-10 Cam
13.36@104.24
Excited I’d be for sure! The time comparison is big.
What do you have for rockers and the converter stall?
They are 1.5 roller tip Comp rockers and a stock High stall converter that maybe flashes to 2500. Lots of room to tune the 60 foot for big improvements!
Cley
74 Duster
Comp XR274HR-10 Cam
13.36@104.24
Very happy for you, my friend! The 104 mph says "yes", 12's is there.
I did change my name!
Cley
built a 69 Dart for my grandson 318 std bore with ross pistons zero decked 596 heads with 2.02/1.60 ferrera valves CNC ported by KG engines purple 508 cam hooker headers 1 5/8 10" 501 converter 904 trans 4500 stall 3.21 gears weighs 3150.we took to TNT at muncie dragway wearing stock set of radials
1st run 14.53 blew tires off for better than 200 ft. 103mph
2nd run i babied it out of hole still spun them past lights got out of it and ran 13.43 104mph
3rd run put my grandson in it he grannied it out of hole past 60ft then hammered it 13.93 103
4th run i said put in 2nd gear and leave it aint hooking on street tires it spun tires hooked about 60 ft and ran 13.57 104mph
We think it has a 12 in it i finally got some drag radials on it but havent time yet for some tnt the converter is set up for 4:10's those will be for next year
want to thank everybody for the thumbs up ill keep you posted on our quest for 12's
couple of pics of car which we affectionately call "Wimpy" she aint no beauty but you dont have to look good to go fast.some stuff i done to car new floor pan 1 piece and I rebuilt front suspension has cal tracks on all corners.It has a 700 dbl pumper rear is a 8.25
Looks better than my dart, and I probably won't be doing any cosmetic stuff to mine until I know it goes straight and stops.
I ended up having an axle nearly come out of a 8.25 so just beware of the c-clips.
Give them an inspection every once in a while for your grandson and your safety.
have an 8 3/4 backed braced with 35 spline moser axles that will go in next year and im watching the 8.25 safety is priority #1.another upgrade is disc brakes i have a LEEDS conversion kit going in it.
not the right thread but car in my avatar has finally broke 11 second barrier thats another story
I will at some point go to strange disc brakes on my Dana 60 but till then 11 inch drums will probably be just fine
