Sorry you thought my post was lame, but that's how I feel. You made a spreadsheet up of other people's tire and wheel combo's. That sounds pretty lame to me.
My point was, measure YOUR car and determine what will fit. Why rely on other people to tell you? And how can they tell you unless they come to your house and measure your car for you?!? Again, I don't care if someone copies my set up, but I don't want them to be disappointed when it doesn't work on their car.
I think your post was "lame" because the OP asked for wheel combo's and you came back with "Why?!?". Who cares? He wanted to know.
These cars are different, but they aren't
that different. Unless you have a really spectacular example of a Monday morning or Friday afternoon car, they're usually within a 1/4". I made a spreadsheet of other peoples wheel and tire combo's because it allowed me to figure out almost exactly how much clearance I needed to run the wheel and tire combo
I wanted. You know, before I spent $2k+ on rims and tires? And it had very little to do with the actual amount of space under the car.
Simply measuring won't tell you everything. Sure, it will tell you if a certain combo will physically fit in the stock wheel tub, but it doesn't tell you that 5/16" is all you need to the springs, but a 1/4" won't work. Or that a 1/2" can work on the quarters if you don't have a lot of body roll. But people that run that amount of clearance
can, even if they don't have the same size wheels. Because everyone runs different size tires with different backspacing. A guy running 225/60/15's with 3.5" of backspace can tell me as much about clearance as a guy running 275's, maybe more. I couldn't find anyone that was running 295's on 18's on a lowered Duster , but I still figured out that I could do it, and confirmed it with my own measurements.
And seeing what is possible gives you ideas. So, why not?
Seriously, back to the topic. Someday I may want to mini-tub my car!
Here's some info from 72BBswinger since I haven't seen him post here yet. He runs 335's on his Dart...
18x9 F 6.45bs + Dr. Diff rotors + 3/8" spacer, 18x12 R 9.2"bs on a 67 B body rear axle. The rears were 18x10 7.2"bs on a stock A body rear and fit pretty much perfect.
