Post your times and build!
GoodysGotaCuda
Mr. Goody
DFW, Texas
Fast or slow, lets see if we can get a on-going thread here on what everyone is running and with what. Quote this first post and fill in your info.
:wav:
Car:
Weight:
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc):
Slip
Reaction Time-
60 foot-
330'-
1/8th Mile-
MPH-
1000'-
1/4-
MPH-
Build - Engine
Cubic Inches:
N/A, Forced Induction (Pounds), Nitrous (HP Shot):
Cylinder Heads (Aluminum, Cast, Ported, etc):
Compression Ratio:
Cam (Hyd/Solid/Roller - Specs):
Intake Manifold:
Carb/E.F.I:
Exhaust:
Ignition:
Transmission
Type: (904, 727, 4speed, etc):
Shift Kit:
Torque Converter (Brand/Stall/Size):
Rear
Size (8 1/4, 8 3/4, Dana, etc):
Gear Ratio:
Differential:
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock):
Shocks:
Tire Size:
Tire Type (Radial, Drag Radial, Slick):
GoodysGotaCuda said:
Car: 1972 Barracuda
Weight: 3,600lbs
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc): 2,100ft track elevation. 5,200ft density altitude.
Slip
Reaction Time- .004 - Pro-Tree
60 foot- 1.9
330'-5.7
1/8th Mile- 8.9
MPH-75.7
1000'-11.7
1/4-14.0
MPH-95.3
Build - Engine
Cubic Inches: 323 (318 .030)
N/A, Forced Induction (Pounds), Nitrous (HP Shot): N/A
Cylinder Heads (Aluminum, Cast, Ported, etc): Stock port 2.02 J-heads
Compression Ratio: 9.7:1
Cam (Hyd/Solid/Roller - Specs): Hyd Comp Cam, .480lift/280duration
Intake Manifold: Performer RPM
Carb/E.F.I: 650cfm Thunder AVS - Edelbrock
Exhaust: Dynomax Headers - 3" Cutouts
Ignition: MSD 6A, Blaster Coil, Heli-core Wires
Transmission
Type: (904, 727, 4speed, etc): 904
Shift Kit: TransGo TF-2
Torque Converter (Brand/Stall/Size): 9 1/2" Dynamic. 3,500rpm Footbrake
Rear
Size (8 1/4, 8 3/4, Dana, etc): 8 3/4"
Gear Ratio: 3.91
Differential: Clutch Sure-Grip
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock): Super Stock
Shocks: Summit Adj Drag Shocks
Tire Size: 26x10x15 on 15x7 wheels
Tire Type (Radial, Drag Radial, Slick):Slick - ET Drag
:rambo:
Car: 66 cuda
Weight: 3400 w/ driver
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc):cold dry low
Slip
Build - Engine
Cubic Inches: 360 std bore
Cylinder Heads (Aluminum, Cast, Ported, etc):stock 78 heads w/ air injection holes plugged 1.88's
Compression Ratio: 9.6:1
Cam (Hyd/Solid/Roller - Specs):mopar p4452992 474 lift 280 adv dur
Intake Manifold:eddy street ram
Carb/E.F.I:2 - holley 390's with balance tube, and light spring
Exhaust:spitfire headers and dumps
Ignition:mopar chrome box, jacobs coil
Transmission
Type: (904, 727, 4speed, etc):904 low gear
Shift Kit:
Torque Converter (Brand/Stall/Size):dynamic 9.5" built to spec
Rear
Gear Ratio:3.23
Differential:limited slip
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock):S/S
Shocks:kyb
Tire Size:26 x 9.5
Tire Type (Radial, Drag Radial, Slick):slick
cant wait till its gets cold again, the slip is from last year without low gear and without dynamic converter!
:wav:
Car:72 duster
Weight: 3350
Slip
Reaction Time-
60 foot-1.5018
330'-
1/8th Mile-6.999
MPH-96.72
1000'-
1/4-
MPH-
Build - Engine360 stroker
Cubic Inches:414 510 hp 510 tq
Cylinder Heads (Aluminum, Cast, Ported, etc):W2 as cast
Compression Ratio:11.00
Cam (Hyd/Solid/Roller - Specs):flat tappit comp. special grind
Intake Manifold:street dominator
Carb/E.F.I:850 Quick fuel dp
Exhaust:hedman hustler
Ignition:msd dist 6al box
Transmission
Type: (904, 727, 4speed, etc):904 low gear set
Shift Kit: manual valve body
Torque Converter (Brand/Stall/Size):ptc 5500
Rear
Size (8 1/4, 8 3/4, Dana, etc):8 3/4
Gear Ratio:430
Differential:moser
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock):cal-trac -cal-trac springs
Shocks:9010
Tire Size:
et street radial
Lets give it a try with my boys Dart:
Car: 72 Dart
Weight: 3710 with 170 lb driver
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc): 500 ft
Slip
Reaction Time-
60 foot- 1.61
330'-
1/8th Mile- 7.33
MPH- 93
1000'-
1/4- 11.55
MPH- 116.23
Build - Engine .030 over 400
Cubic Inches: 406
Cylinder Heads (Aluminum, Cast, Ported, etc): Stock Eddy's
Compression Ratio: 10.2
Cam (Hyd/Solid/Roller - Specs): MP solid .557
Carb/E.F.I:[/b ] 750 DP
Exhaust: 3" with flowmaster's
Ignition: stock dist with MSD
Transmission
Type: (904, 727, 4speed, etc): 727
Shift Kit:Reverse Manual v/b
Torque Converter (Brand/Stall/Size): 9.5 Dynamic - 4200 flash
Rear[/i
Size (8 1/4, 8 3/4, Dana, etc): 8-3/4
Gear Ratio: 3.91
Differential: posi
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock): SS springs
Shocks: MP
Tire Size: 26 x 9.5
Tire Type (Radial, Drag Radial, Slick):[/QUOTE] Hoosier QTP
I will post my 63 as soon as I get it to the track. Hoping for mid to high 11's and she feels like it should. Ron
:wav:
Car: 70 duster
Weight: 3480 with me in it
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc): Sucked
Slip
Reaction Time-.539
60 foot-1.35
330'-
1/8th Mile-
MPH-
1000'-
1/4- 9.67
MPH- 142
Build - Engine
Cubic Inches: 440
N/A, Forced Induction (Pounds), Nitrous (HP Shot): none now!!!!
Cylinder Heads (Aluminum, Cast, Ported, etc): indy -1s out of box
Compression Ratio: 13 to 1
Cam (Hyd/Solid/Roller - Specs): soild roller 328/332 660/662
Intake Manifold: indy single
Carb/E.F.I: AED 1050
Exhaust: 2in header with walker mufflers
Ignition: msd 6al, msd dis, crank trigger
Transmission
Shift Kit: Tci
Torque Converter (Brand/Stall/Size):5500 stall ati
Rear
Gear Ratio: 4.10
Differential: moser spool
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock): S/S Springs
Shocks: Front- stock Rears - heavy duty truck
Tire Size: 29.5x 11.5 - 15 M/T
Slicks
Alright, y'all are gonna laugh at me but I gotta get in on this.
Car: 1999 Dakota Sport 2WD
Weight: 4,045 w/ driver
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc): 104* F, 1,243 ft, 11%
Slip
I'll upload it later if I can, I'm actually on my laptop right now...
Reaction Time- .520
60 foot- 2.211
1/8th Mile-
MPH-
1000'-
1/4- 15.430
MPH- 85.4
Build - Engine
Cubic Inches: 318
N/A, Forced Induction (Pounds), Nitrous (HP Shot): NA
Cylinder Heads (Aluminum, Cast, Ported, etc): Stock Magnum
Compression Ratio: stock
Cam (Hyd/Solid/Roller - Specs): http://www.cranecams.com/?show=brow...ize=5.2 L&partNumber=704115&partType=camshaft
Intake Manifold: stock
Carb/E.F.I: EFI
Exhaust: 3" DynoMax w/ straight pipe & Ultra-Flo canister
Ignition: stock w/ bosch platinum +4 plugs
Transmission
Type: (904, 727, 4speed, etc): Stock 5-Speed hydraulically-assisted truck tranny
Shift Kit: my right hand
Torque Converter (Brand/Stall/Size): N/A
Rear
Size (8 1/4, 8 3/4, Dana, etc): 8-1/4 truck
Gear Ratio: 3.92
Differential: factory limited slip
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock): stock leaf rear
Shocks: stock
Tire Size: 235/70-15
Tire Type (Radial, Drag Radial, Slick): crappy All-Terrains (haha)
Spun the tires into fourth gear, and didnt get a second run. I just took the truck down for the hell of it because I thought it would be funny. My friends were laughing at me the whole time, I had the only truck on the track and I got beat by a freakin Subaru wagon... :scratch:
:wav:
Car: 7T1 Dart
Weight: 3340
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc): No Idea......Elevation about 700- 900 feet
Slip
Reaction Time-sleeping
60 foot-1.71
330'-
1/8th Mile-8.338
MPH-81.46
1000'-
1/4-13.148
MPH-102.26
Build - Engine
Cubic Inches:340 .030 over
Cylinder Heads (Aluminum, Cast, Ported, etc): 360j heads with bowl blending and gasket matched
Compression Ratio:About 9.7
Cam (Hyd/Solid/Roller - Specs): Mopar 474
Intake Manifold: Eddy performer
Carb/E.F.I:650DP
Exhaust:Through open headers
Ignition:All msd,,,,6al and distributor
Transmission
Type: (904, 727, 4speed, etc):833 with a broke dick hurst shifter
Shift Kit:
Torque Converter (Brand/Stall/Size):Stall is controlled by my weak foot
Rear
Size (8 1/4, 8 3/4, Dana, etc): Narrowed 8 3/4 with moser axles
Gear Ratio:3.91
Differential:clutch type limited slip.
Suspension/Tires
Spring Style (Cal-Traks, S/S, Stock):1969 4 door dart leafs with 3 link traction bars and tortion bars out of the same car.
Shocks:KYB in the rear
Tire Size:27x 10.50
circle track hoosiers
Car is also mini tubed with frame connectors. all steel, full interior and crappy paint.
New improvments are on the car, waiting to go to the track.
Proform main body on the carb, aluminum case 833, new ram 3200lb clutch, Fixing pinion angle this week, and the most important, a new shifter.
halfaed said:
I am getting into the 12s :) wish me luck!!!!!!!!!!!!
With that 60ft time and ET Trap speed... 12's are in your future with nothing more than a bit of practice....
Good luck... I am think 12.87 @105.... just a guess...Go get em
I have been having problems shifting with the old hurst shifter. Once that is fixed, I'm thinking the same thing you are! :)
Car: 71 scamp
Weight:3300lbs
Track Conditions (Elevation, Heat, Humidity, Density Altitude, etc, etc):[/b]
Slip
Reaction Time-
60 foot-1.67
330'-4.7
1/8th Mile-7.2
MPH-95
1000'-9.5
1/4-11.47
MPH-115
Build - Engine-340 (.030 over)
Cubic Inches:416
N/A, Forced Induction (Pounds), Nitrous (HP Shot):[/b]
Cylinder Heads (Aluminum, Cast, Ported, etc):unported eddy heads
Compression Ratio:12to1
Cam (Hyd/Solid/Roller - Specs):comp cam .570 solid flat tappet
Intake Manifold:victor 340
Carb/E.F.I:750 holley with pro form main body
Exhaust:tti step headers into 3" exhaust with dynomax bullits
Ignition:mopar dist. chrome box
Transmission
Shift Kit:griner reverse valve body
Torque Converter (Brand/Stall/Size): PTC 5200
Rear
Size (8 1/4, 8 3/4, Dana, etc):83/4
Gear Ratio:4.30s
Differential:[/b]
Suspension/Tires[/i]
Spring Style (Cal-Traks, S/S, Stock):stock with cal tracs
Shocks:90/10
Tire Size:26x9.50
Tire Type (Radial, Drag Radial, Slick):hoosiers qtp
