Post your wheel and tire combos.
Car year and model 1965 Barracuda
Front
Wheel Brand Kenda
Size 14
Backspacing ???
tire size 205/70 14
Suspension mods KYB front shocks
Rear
Wheel Brand Kenda
Size 14
Backspacing ???
tire size 205/70 14
Suspension mod KYB Shocks and Poly Bushings
This is the wheel with center caps and rings. Cap is just kinda set in the hole right now, need to drill the mounting holes and then she's good to go.
I have seen this car around in Salem a lot. Definetly catches my eye everytime ;)
I finally collected a set of ralleys.
1972 Dart Swinger
Front
Wheel Brand Mopar Ralley
Size 14x5.5
Backspacing 3.5
tire size 215/70R/14
Suspension mods none
Rear
Size 14x5.5
Backspacing 3.5
Rear 15x10 7.5 BS Weld Racing Draglites BFG 295/50/15 B Body rear springs move in to the frame and mini tubbed
Front 15x6 3.5 BS Weld Racing Draglites BFG 225/60/15 stock front end
67 cuda convertible front 15x4 cragars with micky thompson s/r, rear will be 15x14 cragars with 29x18 micky thompson s/r, they look tough in the garage floor till aug when it goes in for a tub job
I know ive posted mine already but here is latest pic with the rear wheels widened to 18x12. Front to rear sidewalls look alot better now.
Nice look. Been looking a bit for 18 x 12s. Everything is $$$.
Mind giving details?
I sent them to Vaughn Machine to be widened. Not cheap but a whole lot cheaper than a set of billets. Also put in a 67 B body rear. Wheels have about 9.2" of backspacing now.
15x6 front w/ 4" backspace - 205/65/15 radials
15x7 rear w/ 4.5" backspace - 235/60/15 MT Drag Radial
Stock suspension front to back...
SBP wheels by Specialty Wheel painted in Sherwood Green Metallic to match the car!
sweet car man, but it looks like your rear tires are on the wrong sides...(rotation is wrong)... im not dogging you i just thought u should know.
Updated...just installed 275/50/15 BFG Drag Radials....no suspension mods except a 1/4" spacer.
just so i am clear????
I bought a 71 Duster, will a 15x8 with 4.5 BS and a L-60x15 or 275x60x15 Fit in stock wheel well with springs in stock location?
Saw a 71 Demon at a local car show tonight, and he said thats what he was running. it looked real close to the springs.
Sorry i thought i had posted that earlier? 71 duster with an A body 8-3/4 actual L-60x15 Mcreary tire.
