Post your wheel and tire combos.
I had thought of going to the 7 in. with the 4.125 bs but on another post of mine a reply mentioned that I may have a problem with sway bar clearance if over 4 in.bs so I played it safe and went with 6in rims and less bs.
I need new tires on my 69 Dart GT vert after recent blow-out. Currently have 7" Cragers all the way around with 225 60x14 on all.
I want to leave the 225 60x14 on front but go to 245 60x14 on rear... for slite wider look. Any clearance issues? I see it should be ok height-wise but its gonna be close at the fender. I dont think the rims are offset.
Or should I just go 235 60x14 or just leave well enough alone and stay with what I have?
Any ideas...?
These are the specs on 60 series BF Goodrich TA:
TIRE----Rim----Sec width---OA dia----Rev
225.......6.9"........9"...........24.7".........842
235........7"........9.5"..........25.1".........820
245........7"........9.8"..........25.6".........813
245/60/R14
215/70/R14
I'm not sure on the rims, but the rear are probably 3 inch offset, 14*7.
The fronts look like 14*6.
Any ideas...?
See if the tire shop will put a 245 on just to see how it looks,and check for clearance. Make sure you try it on both sides,Mopars rear end is not centered .
Only problem is not many tire shops stock a 60 series 14" tire. The place Im getting them from is having them shipped. Guess I could make a few calls and see who may have a set to compare...
Ill have to remeasure the rims- I thought they were 7" all the way around.
Car year and model 67 Dodge Dart GT Convertible
Front sbp rallyes
Wheel Brand
Size 14
Backspacing stock
tire size 215 70r14 Hoosier GT
Suspension mods none
Rear
Wheel Brand sbp rallyes
Size 14
Backspacing stock
Suspension mod none
So 245/60 15s should work on my 66 cuda? Does anyone know how large of tires can be put on without any suspension mods.
Pictures sometime next week when I get the wheels. :D
I'm putting that size on next week with a set of keystones on my 65 barracuda ...I'll let ya know!
I currently have a very old set of 195 70 R14's on my stock 66 Barracuda Formula S. I am thinking about going with a 205 70 R14. For those of you with stock 66 Formula S wheels, what size tire are you running?
Car year and model 69 Cuda Formula S
Front
Wheel Brand Vintique mopar classic
Size 14 x 6
Backspacing
tire size 225/70
Rear
Size 15 x 8
Backspacing 4.5"
tire size 275/60
Suspension mod none
Really tight fit in the rear, should have gone with a higher offset, but so far no scraping at all
205/70-14 is a great choice for an early A.
Here's my new set of shoes.
Fronts:
American Racing Santa Cruz rims, 15x7, 5x4.5 bolt pattern, 5.56" backspacing
Tires - 205/60/15 BF Goodrich Radial T/A's
Mods - 1.5" wheel spacers to take up the offset
Rears:
Same rims
Tires - 225/60/15 BF Goodrich Radial T/A's
Mods - E body 8.75 axle with perches moved in to A body width, rolled fender lips, still a tight fit. Would probably be just about right with a B body axle, which would let me stuff in some bigger tires =P.
I just switched from 5.90 15 bias tires up front to 165/80R 15
both are VW front tires heres the only pic i have currently
Just got my rims/tires today from Jegs.
15x5 w/205/60/15 for now
15x8 w/275/60/15
Bought a bunch of speed parts also, to many to list right now, still opening boxes!
My 340/stroker is coming together as well. This is a awesome web site, never get tired of looking at everyone elses rides! Tried to post photos, but file is still to large.
Mark
Hi, I have a 1970 dodge dart. What is the exact specs on the rims you ordered so I can use it as an example for my car..
Thank you!
-ANTHONY
15x6 front w/ 4" backspace - 205/65/15 radials
15x7 rear w/ 4.5" backspace - 235/60/15 MT Drag Radial
Stock suspension front to back...
SBP wheels by Specialty Wheel painted in Sherwood Green Metallic to match the car!
Rear
wheels: Cragar S/S 15x8 (2)
tires: 245/60 15s
suspension mods rear: new shackles, shocks, panyard bar, bending the lip on the inside up
Front
wheels: steelies
tires: 185/70 14s
suspension mods front: anti sway bar, shocks, cutting about 1 inch off the front bottom of the wheel well so the tire (on the Cragars) doesn't drag when turning and the nice thing is that it doesn't even look like it.
debating whether to get a new radio or the front wheels first
Car year and model 1967 Barracuda FB
Front-STD steelies
Wheel Brand-Wheel vintiques
Size-15x7
Backspacing-4.25
tire size-205/70/15
Suspension mods-Bone stock rebuild
Rear-STd steelies
Wheel Brand-same as above
Size-15x7
Backspacing-4.25 w/.500" spacer
tire size-275/60/15
Suspension mod-STD spring locations w/SS springs
Fronts: 15x6 Cragars with 3-3/8" backspace from Summit, front tires are Falken 205/65R-15.
Rears: 15x8 steel with 5-1/4 backspace from Specialty Wheel, tires are Nitto 275/50R-15 Drag Radials.
No mini-tub, just stock wheel housing, but I have the offset rear sping hangers (1") and my rear is an early B-body 8-3/4.
15x3.5 26 in moroso front runner, mickey thompson wheels 15 x10 with 4.5 bs. w 30x9 hoosier lt.wt. radial some tweaking done to the front of wheelwell the rest is stock.28 in tire works fine wo. tweaking .
why dont img. show up ?
that car is so beautiful...
