Post your wheel and tire combos.
1973 duster
Front wheels- Cragar SS
Size- 14x6
Backspacing- 3.5
Tire size- 215-75-14
Suspension-stock
Rear wheels- Cragar SS
Size-15x10
Backspacing- 5.5
Tire size- 325-50-15
Suspension- SS springs moved in 1". Rancho adjustable shocks, Rear axle moved back 1" to center wheel, pinion snubber.
Pictures available when files are resized. Stay tuned.
Man that is the look for your car! Did you put some more pictures somewhere that I can drool over?
I think your tire/wheel combo is the next look for my 71 Charger
Ma Snart
front 17x8 30mm offset 235/35
rear 17x8 no offset 245/45
personally i like the tip less duel exhaust.
What are the MFG of your tires and wheels? Have you posted any other pictures of your car where I can better see the wheels. I looked at your gallery but no side view.
Based on wht I can see they look great.
Happy Holidays
Ma Snart
My 61 Chrysler for your viewing pleasure - More pictures in my gallery
All Rims are Crager SS 5 on 4
15*6 " Front 3" bs
215/60/15 BFG Radial T/A
15/8 " Rear 4 1/4" bs
255/60/15 BFG Radial T/A
No suspension mods front or rear. Rear tire to spring clearance a little over 3/4 in.No noticable problems front or rear.
What a great looking 67 Cuda made even better with the Crager wheels!!! That is a classic size combo that fits the car perfect.
Happy Holidays
Ma Snart
1972 Dodge Dart
REAR 15x7 Weld Pro Stars 4.5 backspacing Mickey Thompson street radials 255/60/15
FRONT 15x5 Weld Pro Stars Mickey Thompson Sportsman 26x7.50-15.
Could you please tell us what your suspension mods are if any. Thanks.
It's still on jack stands but will be on the ground soon!!
325/50R15 Drag radials on 15x10 with 3.5 inch bs Mini tubbed and springs relocated, narrowed Strange 60
195/65R15 Michelin's on 15x6 with 3.5 bs BBP disc brakes conversion
How did you manage not having any rust? Nice Dart!
Back:
stock 15" x 6,5jj with 225/70-15 tires on a B-body axle with heavy duty raised leaf springs.
Front:
stock 15" x 6,5jj with 215/65-15 tires on F-body spindels
69 Dart
Front Rock Crusher D holes 15 x 7 with BFG 235 60 15 BS 4.5 (not pictured, still had the 3.75 BS in this pic)
Rear same wheel with BFG 235 60 15 BS
[/IMG] 3.75
Thanks! It has some slight bubbling over one of the rear wheels and behind the quarter on one side. It's been painted once, it was originally a red car. Here is how she looks now that she is back on the ground and ready to cruise.
70 Duster: Summit Warrior R/T's all around.
15x4 w/ 1.75" BS - 165R skinnies...
15x8 w/ 4.5" BS - 255/60/15 Radials for now...
Mini-tubbed, but all suspension in stock location, however all converted over to big bolt pattern...
Updated...just installed 275/50/15 BFG Drag Radials....no suspension mods except a 1/4" spacer.
1973 4 Door Dart Custom 318/904
No suspension mods aside from saggy springs and fresh shocks.
Wheels - 17x7 steel takeoffs from a 2006 Dodge Magnum
Tires - 205/50ZR17 Federals
eBay 17" trim rings
Rallye center caps being shipped now.
Looks pretty rubber bandy, next set will probably be 215/65's or 225/60's but I need power steering before I go to wider tires up front and more gear before I run a taller tire in the back.
:shock: whoa !!!
Just you wait. She pitched a head gasket which I'm using as an excuse to pick up a 5.9 Magnum out of a 98 1500. Explorer 8.8 swap pending. Then some much needed handling work. So excited. I'm really really pleased with how the 17's are turning out, I did a lot of Jeep and Intrepid/300C/Magnum forumlurking to find out if center caps and trim rings fit and they look just like I wanted them to (well, they will once the wheels are coated, still deciding on color). Hot Wheels!
:burnout:
Oh, right the paint. It's great for getting school kids to shriek, rednecks to give me thumbs up from the bus stop, and making soccer moms shake their heads angrily. And kinda sorta keeping the rustmonster off the body panels, but it's a PO's crackly housepaint nightmare up close. It's fun driving the Zebra Car, and everybody around town is "sure they've seen it before", including the guy who put the tires on, but I'm not sure I'm into animal print long-term. It's not a sure thing but there's a decent 80's metallic blue repaint (fender tag shows white/blue interior) hiding under most of the places it's chipped up, I've half a mind to get out there with the thinner and some rags and see if I can save it, but I'm afeared I'll spend ten hours to reveal a huge bare spot on the roof/hood/trunk.
There was another Zebra Dart in Portland for a few years - I kind of think only the back half was done, though. it's on the east coast now, running in vintage road racing. I'm sure there are pics on the web somewhere. It was an early A, a 65 or 66, IIRC. Still a great look in my book!
Clair
Wow, the proportions of your wheels and tires are perfect for your car!!! Really looks great (and will help it bite the track)!!
Ma Snart
My Cuda with the previous wheel/tire set up
eBay 17" trim rings
This is the wheel with center caps and rings. Cap is just kinda set in the hole right now, need to drill the mounting holes and then she's good to go.
