racerkilla
I dont think the bellhousings are the same... I wanted to put a mopar small block in my amx and wouldn't line up.
They did make a 727 for small block mopar and also a 727 with amc bellhousing.
I put a t5 in my 79 amx though. Had an sr4 4 speed with multi pattern bellhousing. Still had to change the bearing retainer as the stock ford t5 had a larger retainer and wouldn't fit into my bell. Also had to cut the bearing retainer down some where the throw out bearing goes on so it wouldn't contact the clutch disk do to ford/amc bellhousing height differecne
