Power steering box Rag Joint
Kendog 170
Let the boy go !
Reading Ma.
So I have play in my rag joint. I would like to replace the stock one with a newer swivel type. It seems you have to cut the steering shaft to do this installation which I don't want to do. Does anyone sell a pin in direct replacement ? It's a stock 68 Dart power steering setup
I did find this but too pricey for this cheap old f*7^.
Mopar Universal Joint Adapter - Power Box - FR1506P - 574 - 5367
No rag joint on a '68 Dart. It's got the standard coupler that is in most Mopars of that era. It can be rebuilt of replaced.
Is this it? Tony’s Parts has them.
Mopar stock coupler was miles ahead of the GM stamped circle O tire cord w bolts setup that they used for years. Rebuild the stocker, add that stainless wire retainer and be done with it
Ford and others used a coupler with canvas link in it. That is where the slang term "rag joint" comes from. Chryslers engineered box coupling never was referred to as a rag joint and shouldn't be. Aftermarket is either showing their ignorance or bumping search terms for buyers who don't know the difference.
Edit; aftermarket calls this a rag joint too yet there is no "rag" in it either.
For Ford F150 Steering Shaft Coupler Rag-Joint Universal U-Joint 8L3Z3B676B | eBay
Only 27 bucks for all of that? Must be produced in large lots in China. There wont be similar production of our box coupling that can be kit rebuilt.
I only said Rag Joint as that was what we called them back in the 70's. I will just replace with the new kits.
For most, The worst part of the rebuild is the cap. Factory used a bottle cap like crimp. The kit will include a new cap and you can find threads here detailing how members have managed to recreate the factory like crimp using the new cap in the kit.
I was taught to distort the original cap just enough to pop it off, like a bottle cap, so I could reinstall it.
The cross pin is a very tight press fit into the shaft. Most of the time it isn't worn enough to warrant R&R. I've replaced only 2 of them. If you do need to replace it you will need a press to get it changed and centered. Disassemble the column, take shaft alone to the press.
I did R&R 1 of the 2 with a hammer. Took some doing to get it close to centered. I settled for about ten thou' of centered. Good luck with yours.
Exactly! Easier to just pull the column and remove the shaft. I did that when I replaced my lower column seal/bushing and rebuilt the joint while I had it all apart. What a difference it made.
yeah, we never know what we'll find when we dig in. For my 67,, I didn't know the upper bearing was crusty, roared, and needed replaced before the column reached the workbench.
It's all good now though. Ready for another 50 years. LOL
I flipped the square tabs over and re-inserted. That how loose it is.(Temporary of course).Took all the play out there but definitely have some play in the column (maybe bearing?) so I will pull that and go through everything so I'll get another 50 Years as well.
Thanks for all the input.
A guy at work was told by the service he needed a new “doppleganer joint”. Or some german term for his Mercedes Ml350 for $750.. when he dscribed the part I said ...Oh A rag joint.
He laughed at me until he pulled up a pic on the net. Damn thats an expensive rag joint !
As for holding the top on the coupler . I bought a few spring clips made to retain it on off of Ebay and it works quite well.
