Good afternoon all,
I have a question about a spare Powerglide transmission that I have for my Super Pro Arrow. When I bought the car the previous owner threw in a spare powerglide and torque converter in the deal. I never really paid attention to the spare PG but a couple of weeks ago I got to thinking that I should know what's in it. I know it's a 1.80 gear set, has a manual forward valve body with brake. Called up the previous owner to ask if that trans is ready to go as is. He said it is fresh and ready to run but to keep in mind it has a stock planetary gear set in it. I asked if I could run that in the car if the trans that's in it ( with all the good parts) were to ever break and he said yes.
My question is, is this safe to run with a stock gear set? I have my doubts but I'm no expert on powerglides ( or any other transmission for that matter!). I run the car fairly conservatively, launch RPM between 3800 - 4000 and shift at 6500 - 6800 depending on conditions. So is this safe to use if needed, or should I consider spending the money for an aftermarket planetary gear set?
Thank you.
Thank you.
