Preheating Joe Gibbs break in oil to 180F
Small Block Mopar Engine
  1. tanis4457
    tanis4457 Well-Known Member
    267
    62
    Apr 22, 2015
    Seattle, WA
    Local Time:
    9:41 PM
    I noticed with the Joe Gibbs BR break in oil, they recommend getting the temp up to 180F prior to firing. Does anyone do this if so, what method? Pot of hot water with the quarts in there? Thanks
  2. rustycowll69
    rustycowll69 Well-Known Member
    1,715
    665
    Feb 19, 2016
    Pacific northwest
    Local Time:
    9:41 PM
    you can install a "soft plug" heater. My 79 300 w/360 came with one, as an option, from the factory. they also make heater blankets you can place on the outside of your oil pan. I don't know that they will get to 180 degrees, though.
    • Like Like x 1
    • General Disarray
      General Disarray Well-Known Member
      164
      118
      May 4, 2018
      South Park
      Local Time:
      10:41 PM
      For me, no. There are a couple of companies, like JGR, that recommend this practice. Most other mfrs do not. I use Valvoline products, have not, do not, pre-heat the oil. People can get as anal as possible about stuff, but this seems like overkill. Besides, Valvoline is $4 / quart cheaper. $20 bucks buys a couple of filters.
      • Like Like x 1
      • Agree Agree x 1
      • T56MaxTorq
        T56MaxTorq Well-Known Member
        835
        231
        Dec 21, 2010
        CO
        Local Time:
        10:41 PM
        Depending on where you live, you could probably just leave the quarts of oil in a hot car parked in the sun for a couple hours.
        Or if you have an outdoor bbq with a side burner, pour all the oil in a pot and heat it up like a turkey fry.
        I was once stationed in Alaska and in the dead of winter, the gearbox on my Jeep was frozen solid after getting stuck in the bogs the day prior. The oil was too contaminated with water that the engine could not turn it over. Flipped over a trash can lid, put hot charcoal briquettes in and slid it underneath. Changed the oil and I was good to go!
        • Like Like x 5
        • mbaird
          mbaird mbaird FABO Gold Member
          4,104
          1348
          Dec 10, 2005
          boise, Id
          Local Time:
          10:41 PM
          Get a magnetic oil pan heater then return it once engine is broke in...
          I understand the zinc isnt active until a certain temp. Or something to that effect???
        • TrailBeast
          TrailBeast Slightly Twisted Member
          19,333
          5730
          Mar 11, 2011
          Arizona
          Local Time:
          9:41 PM
          Unless it's warmed in the motor it'll never be 180 once it gets in the motor anyway.
          I guess a person could be as careful as possible because of what's at stake, but I have NEVER seen anyone actually do that.
          • Agree Agree x 1
          • yellow rose
            yellow rose Doctor of Thinkology.
            15,388
            12025
            Jun 19, 2015
            Living on the razors edge
            Local Time:
            9:41 PM
            It's warm enough here to start without a preheat.
            Are you taking video of this? I for one am damn sure interested!!!!!
            Can't wait to hear it run.
          • mbaird
            4,104
            1348
            Dec 10, 2005
            boise, Id
            Local Time:
            10:41 PM
            I broke a motor in during the winter once ... left the magnetic heater on overnight then filled the radiator with hot water prior to start up.
            I have no idea if it made a difference .
            • Like Like x 1
            • Thanks! Thanks! x 1
            • nm9stheham
              nm9stheham Well-Known Member
              10,134
              2481
              Dec 20, 2013
              Waynesboro, VA
              Local Time:
              12:41 AM
              I've never even imagined doing this LOL. Maybe I just lack imagination.....Used Gibbs break-in and just ran it at room temp. Honestly, I think the type and quality of the cam lube is the key things. Moly paste only for me...
              My understanding from repeated readings of scientific descriptions is that it is pressure that primarily promotes the formation of ZDDP protective films. And I've seen nothing saying it simply won't work at much lower temps; just that it forms a film faster at some higher temps.
              Which makes me wonder if part of the beneficial reason to keep the RPM's up is to get the oil temps up and speed up the ZDDP action.....???? Hmmm....
            • 72Dart6pack
              72Dart6pack Harder Better Faster Stronger.
              2,819
              1847
              Feb 1, 2016
              Roseville Michigan
              Local Time:
              12:41 AM
              I've worked in Dyno for 38 yrs for one of the Big 3. It's to reduce friction on start up. If your OCD it does work. But over kill.
              • Thanks! Thanks! x 2
              • Like Like x 1
              • mbaird
                4,104
                1348
                Dec 10, 2005
                boise, Id
                Local Time:
                10:41 PM
                But it made me feel really smart and that was worth something.
                Lol
                • Like Like x 1
                • 72Dart6pack
                  2,819
                  1847
                  Feb 1, 2016
                  Roseville Michigan
                  Local Time:
                  12:41 AM
                  We did it on most of the high Hp motors on the Dyno. Not so much on the stock or cheap ones.
                • nm9stheham
                  10,134
                  2481
                  Dec 20, 2013
                  Waynesboro, VA
                  Local Time:
                  12:41 AM
                  Is the idea for reduced friction from the oil being thinner, thus flowing better?
                • 72Dart6pack
                  2,819
                  1847
                  Feb 1, 2016
                  Roseville Michigan
                  Local Time:
                  12:41 AM
                  Yes thick oil pumps harder. Plus if you heat the oil in the pan the block warms up too. Nascar does it in the car. Their oil tank has a heater in it. This is very standard stuff for the Big 3
                • sireland67
                  sireland67 Well-Known Member
                  7,632
                  1655
                  Oct 27, 2010
                  WV
                  Local Time:
                  12:41 AM
                  Kats sells a magnetic heater, that you can stick on the oil pan.
                  I use it in the dead of winter help my old stuff start easier.
                  It runs around $30 bucks and can be used on anything like thawing water pipes etc.
                • ou812
                  ou812 Well-Known Member
                  1,381
                  184
                  Jan 15, 2005
                  SoCal
                  Local Time:
                  9:41 PM
                  We had one of Driven's techs at our shop during a dyno session with John McGann of Car Craft, running a sb mopar. The tech told us the reason they like to see 180° is they claim that's when the additives "work" or "energize". Nothing was said about heating the oil prior to startup...and he was there for that. And once the oil reached 180°, they attach themselves to the metal parts of the engine helping reduce startup wear. Was interesting.
                  • tanis4457
                    267
                    62
                    Apr 22, 2015
                    Seattle, WA
                    Local Time:
                    9:41 PM
                    Thanks for the info everyone, I'm planning on capturing vid of the start up. I'll add it to my ongoing engine build thread when I get it.
                  • Ottmundr
                    Ottmundr 68 Fastback
                    3,988
                    5348
                    Oct 5, 2012
                    Sonoma
                    Local Time:
                    9:41 PM
                    I am far from a petrochemical engineer, but I do build drones which use high performance piston engines. We do use the Joe Gibbs break in oil when breaking in engines. We do not pre-heat the oil, and the engineer in charge of the engines is as anal as all get out.
                    Our protocols do call for warming up the engines at specific rpm settings prior to flight. As well as changing oil between flights.
                    These drones do operate in environments with a bit more sand than the average American muscle car experiences, and they do just fine.
                    Plenty of people break in flat tappet cams every day without pre-heating the damn oil.
                    Preheat your oil, or not. It's your call.
                  • yellow rose
                    15,388
                    12025
                    Jun 19, 2015
                    Local Time:
                    9:41 PM
                    Hey Ott...send me a PM when you have a bit of time to chit chat. I'd like to wrack your brain about what you posted if you don't mind? Thanks
                    YR
                  • MOPAROFFICIAL
                    MOPAROFFICIAL Well-Known Member
                    2,983
                    1989
                    Jun 1, 2016
                    breakwater
                    Local Time:
                    9:41 PM
                    What lame brain crap, yeah... uh I'll tell my f1 crew chief to heat that oil before firing the motor.
                    After hearing and reading stuff like that...I start to think half the population were dropped on their heads.
                    • Like Like x 2
                    • Agree Agree x 1
                    • MichaelB.
                      MichaelB. Well-Known Member
                      184
                      149
                      Mar 29, 2008
                      Central US of A
                      Local Time:
                      11:41 PM
                      Just to throw in some data here. I own a NASCAR Stock Car built by Bill Davis Racing that was campaigned by Ward Burton back in the early 2000's. It has a Pontiac 355 siamese block with a dry sump and external oil pump. It is a REQUIREMENT to heat the oil to 180 degrees (all 4 gallons of it) on start up, and even spin that external pump up to 20-30 psi oil pressure for a bit before the starter is engaged. Another racecar I have (2014 Radical) also has an oil heater on board for its Hayabusa four cylinder that has the same requirement before start up (heat to 180). Both cars are fitted with electric probes in the oil sumps. Yes they do it in F1, and any other close tolerance race series engine. Why? Well it does aid in flow, plus it gets the race engine to temperature and ready for RPM much quicker. I am not so sure it "activates" any molecules in the zinc or the like. But it is a real thing. Operating temperature (180) is ideal for a lot of things. They don't like being cold, or too hot. So getting it to 180 before even starting it would be beneficial.
                      • Like Like x 1
                      • yellow rose
                        15,388
                        12025
                        Jun 19, 2015
                        Local Time:
                        9:41 PM
                        You are talkin application specific situations. You wouldn't heat the oil in a Pro Stock engine. It's water thin to begin with.
                        I've never preheated oil on a fire up yet. Not even when I burned alcohol.
                        • Like Like x 1
                        • MichaelB.
                          184
                          149
                          Mar 29, 2008
                          Central US of A
                          Local Time:
                          11:41 PM
                          I have no problem with that. Its just a data point for reference Vs plain old naysayers.
                          • rustycowll69
                            1,715
                            665
                            Feb 19, 2016
                            Pacific northwest
                            Local Time:
                            9:41 PM
                            times change, opinions change. When I was in HS, it was enough to just get a good cross-hatch on the cylinders, then a few years later, people were honing with head torque plates, then it was honing machines, then it was mirror finishes in the cylinders for moly rings, then it was running hot water thru the blocks while honing. My point is what seems over the top now, may be common practice in another decade or two.
                            • Agree Agree x 2
                            • MopaR&D
                              MopaR&D Research And Destroy
                              3,581
                              502
                              Jan 4, 2008
                              Fort Collins, CO
                              Local Time:
                              10:41 PM
                              My understanding is the oil needs to be preheated and primed because the bearing clearances are so big and all the parts have such a tight fit on those kinds of racing engines. Formula 1 engines are built so tight that they won't even turn over unless they're preheated, the pistons stick in the cylinders.
