Pressure linkage on a 66 barracuda
B.Ringer
ALL MOPAR
maryland
I have the Pressure linkage on a 66 Barracuda 340 engine original 904 transmission with factory linkage from transmission to bracket on top of bellhousing hooked up . I Need information and pictures for linkage from carburetor to factory bracket at top of bellhousing . Thanks
The 2bbl and 4bbl bellcrank (that bolts to the back of the head) are different. so is the front link between the carb stud and the bellcrank. If you have an aftermarket intake and carb, that can be a chore trying to get it to work right.
Thanks, yes after market intake and Holley
You might be better off getting a LOKAR cable setup. Even getting the stock 4bbl linkage that year would have to be modified to work properly.
