72golddustermike
One guy said 800 other said 600.Thats without converter.Is that a decent price both guys been in business over 25 years
Do it yourself.
Plenty of reference material out there. Video, books, youtube on tear down and rebuild.
If you can do an engine, brakes, you can do a TF transmission.
This is a timely thread as I've been thinking about swapping my 904 with one I have on a parts car. The one I'm running will not down shift when I go WOT. Kickdown Linkage is set up it's just now downshifting. I saw a post by Trailbeast (I think) about adjusting pressure and thought about trying that first. But I'd like to just do it right. I'm all about buying some books and videos and giving it a try. That way we know it's done right!
Where do you guys recommend getting a rebuild kit from? I see JEGS and Summit both have them. Thanks!
transtar 12008c for a kit.
http://www.northernautoparts.com/part/tk-12008c
some decent places top get parts.
http://www.bulkpart.com/2/category/a904.html
https://www.wittrans.com/dx/cgi-bin...262165eee4b3420d1266ae2fa12124&option=options
trans will come apart as sub-assemblies. I like to lay stuff out in the order it came apart, keeps it simple and visual. Work on each sub assembly individually and it will keep it easier even if it takes a bit more time.
Most of the kits that you'll find from most all the vendors are reboxed parts you can buy elsewhere for a bunch less. Same as year one/classic industries, they just buy stuff from the same vendors you can, then jack up the price.
There are some tricks do building them. Putting 5 clutches in a 4 clutch drum, etc. Set the clutch packs up on the tighter side of tolerances along with shaft end play. It really pretty easy, not the black magic that most trans shops want to suggest that is required.
Get and keep parts - clean clean clean...![]()
Most say it's easy, but then again, most don't measure or change the bushes in the auto.
Once you need to drive out and drive in bushes, it all becomes a little trickier and more specialized tools are required.
I changed mine but you do need the right tools , I had to borrow them from my chassis guy .
Here is a link to my build and it was my first time , I have built 3 now and there not hard to do at all
Link >>> http://www.forabodiesonly.com/mopar/showthread.php?t=303118
