theothergarth
OK, after doing research I have found out you just seat the priming tool in the slot for it and run an electric drill clockwise to prime. Should I be seeing any oil coming out of the valve train? I didn't expect to see it gush out or anything, but I am not seeing any oil up top. I don't have my oil pressure gauge hooked up yet (probably this weekend), but I expect to see pressure when I run the drill...correct? Also, is there a certain speed I need to run the drill?
