Project DartJZ
Here is what Boosted Motorsports did to gain ground clearance for his Viper install.
The oil pump hangs pretty low, so can't really go any further without some kind of a custom oil pump setup.
Nice thing is, it's a rear sump pan so there is some possibility of clearing a k-frame.
I say a death wheel has some real potential.
Almost exactly what I had to do to my J35 for pan clearance.
Here are some A-Bodies from this site:
68 Dart GTE Project
new-turbo-jpg.1715730598
And then this one: Twin Turbo 1971 Scamp Project
Unfortunately, the pictures in the above thread don't load in the thread. But you can right click and open them in a new tab and see them.
Here is the same car on FB - Scrapyard Scamp
And an article about it:
Feathers Ruffled: The 2JZ Mopar - Speedhunters
I wouldn't be surprised if the OP already found all those though.
Only seen the dart build and that's after I thought of it so it gave me inspiration as I knew it would fit nicely in the engine bay. Will for sure check out the other builds. Thanks for the heads up appreciate it
Welcome to FABO! As a life long A-body fan and an employee at a Lexus/Toyota dealership for the last twenty years, I am looking forward to your build! Post a link here when you start it?
Haha. I'm glad a few people get the why, you might not have to like it but at least understand the idea. I will post it here for sure. Just have to sit down and get the pictures and a write up going.
I have a turbo slant six project, but it won't scratch the same itch as a 2JZ. The engine has a very different "personality" and a very different set of challenges to build one. There isn't really a direct Mopar equivalent.
The turbo slant 6 did cross my mind but I needed the JDM itch as you call it haha. Your right about that. It's a great platform and can do as much or as little as you want with the 2jz
