When the cylinder heads are machined 0.065" and the deck surface has been machined 0.030" to get it true, and a thinner head gasket is used, how much does this affect the pushrod length?
What camshaft are you running? If it's a regrind you may not need different pushrods. The only way to know for sure is to measure.When the cylinder heads are machined 0.065" and the deck surface has been machined 0.030" to get it true, and a thinner head gasket is used, how much does this affect the pushrod length?
you might checkout "pushrod geometry for engines" by Straub on utube. he says that at half lift you want the pushrod length that will put the rocker/valve at at a right (90 deg) angle to each other for the most area under the curve.
Figure the stock steel gasket @.019-.021 thickWhen the cylinder heads are machined 0.065" and the deck surface has been machined 0.030" to get it true, and a thinner head gasket is used, how much does this affect the pushrod length?
