Push Rod Length
Dan the man
missouri
When the cylinder heads are machined 0.065" and the deck surface has been machined 0.030" to get it true, and a thinner head gasket is used, how much does this affect the pushrod length?
What camshaft are you running? If it's a regrind you may not need different pushrods. The only way to know for sure is to measure.
Measure to be sure. There are adjustable pushrods made for that purpose.
you might checkout "pushrod geometry for engines" by Straub on utube. he says that at half lift you want the pushrod length that will put the rocker/valve at at a right (90 deg) angle to each other for the most area under the curve.
You’d be far better of going to b3racingengines.com and reading his stuff on geometry.
Figure the stock steel gasket @.019-.021 thick
Then do the math, 30+65=95..then the thinner head gasket....028? So you added .008 maybe...so 95-8=.087 shorter
What heads? .0048 or .0053 per every 1 cc
.087÷.005=17.4 roughly
17.4 cc's removed.
Buddy...that's a ton... be interesting to see how the intake manifold fits without a lot of milling on the faces.. maybe both heads and intake faces to split it up n maybe allow the intake to be used on something else...maybe .
