pushrods for magnum head conversion
its not 524
but u round up maybe but even then thats with the stock LA springs these are double springs with a dampener so these must be pretty strong springs
It doesn't matter what springs you use... that has to do with valve opening pressure. It has nothing to do with lift. In fact, having double springs could hurt you because the opening pressure could be too high.
The stock springs are good to the maximum .525 lift
i said they should be strong i dont know what they are . im going to have them checked. plus im going to brake the motor in without the inner springs
i did check the heads, but ya i have to check to see if i still have clearance and if the springs are too strong for this cam
