adamsredlines
'69 Dart
I got the shortblock put together (318 based 390 stroker) and am getting a few parts together. I have: Scat Crank/Diamond Pistons 1.6 Roller Rockers Lunati Cam ARP Head Studs Electric Fuel Pump Weiand Stealth Manifold Milidon Oil Pump MP Aluminum Valve Covers I need to get a timing set (TBD), water pump (TBD), pushrods (TBD and headers (TTI Step). Stupid question on the water pump, I am seeing 3 varieties. 6 vane, 8 vane standard, and 8 vane severe/heavy duty. Its going to be a street/strip car, see a bit of nitrous....be backed by a 727 and 4.10 8-3/4. Suggestions on which water pump? Will the timing cover have any effect on water pump selection? Once push rod length is determined, any suggestions on which brand pushrods to use? Cam should arrive today so we can start checking for pushrods and PTV clearance.
