Pwr str fluid foaming
when the fluid gets low it whips and foams in the resivoir. Allow it to settle out the bubbles and fill to proper level. You must be loosing a little somewhere. Good luck
Thanks RedFish, yea I have to add about once a week, need to clean everything off and see where it's leaking.
Thanks again Bruce
you're welcome.
Be prepared. Anything other than the return hose and its clamps will be pricey. Good luck :)
