QA1 Suspension
djazzarello
New Member
usa
Hello everyone. I have a 1968 Dodge Dart and I'm going to install a QA1 suspension kit, part # 122-52344-S400. This setup requires 18" wheels in the front. My questions are: What brand wheels have people used? What size wheel width? What backspacing? What brand tire and size? Also, on the rear, which is stock, I need to know the same information for the rear wheels and tires.
Thanks in advance,
Dennis
You may want to re-check that 18" wheel requirement. Wheel diameter size normally is limited by brake package, not suspension. I realized most...., but not all :).... modify the spindle steering arm which can require at least a 15" rim, but even 16" rims normally clear the heim / rod end tie rod end modification.
just a little tip from your old HDK suspension buddy HemiDenny
Why not give HDK a shot at pricing the suspension for your car. It looks like the QA1 stuff is selling for $5200.00 plus right now.
18 inch sounds awfully big are you sure thats right? Who would you need big wheels for new suspension?
