DrillNFill
Hi everyone! I could use some advice. I have a 1970 Dart Swinger Slant-6 with the standard gauge cluster. It has worked pretty normally for me the past 5 years that I've owned it until this past fall, when I had an upholstery shop replace seat covers and dash pad. Since the day he changed the dash pad, the two left gauges for Temp and Fuel are completely dead and dont work at all. They worked fine previously, like in the photo below from last year. Speedo, alternator and Oil light work normally. I assume the upholstery guy messed up something when he was fiddling under the dash pad.
My old-school mechanic already replaced the cluster voltage regulator and the Temp and Fuel gauges are still dead. He recommended replacing the circuit board as the next step. I already purchased the one pictured below which I believe is the correct one for a 1970 Dart with standard gauges.
Assuming that they stopped working because of the dash pad replacement, and the rest of the car is fine, could there be any other cause of the non-working gauges besides the circuit board? I just want to know if there are any other parts or issues I should be looking into at the same time that could cause this problem. Appreciate any and all advice from you guys!
