skep419
5.9 Magnum 4 speed afficionado
360 xe284 comp cam, stock rods crank, hyper 4 valve relief hyper pistons, ported ede heads, rpm air gap, 750 dp holley hp 727 2800 stall 8 3/4 3.91
"dont want vacuum anything kick in the pants secondaries"
Does this mean you would not consider a vaccum carb?
http://holley.com/TechService/Instructions.asp
I had the bottom end built about 6 years ago. Last year i talked to my engine builder and said i would like a race car that is driven on the street. Went with ede heads new cam, intake heads. If it idles crappy so be it. i would just like the motor to be tuned good i guess.
Thanks for all the help. I plan on checking the power valve and dropping a couple jet sizes and see what happens. But first i will try bumping the timing a tad and see if it pings or better yet starts hahaha
