Quick Fender Tag Decode Help Please For 1971 Dart
A383Wing
Supreme Commander
in my house
Below is copy of fender tag from a '71 Dart...can anybody tell me what the "FO9" is for?
Thanks....Bryan
R11 V5X END
H51 J31 M21 M25 M31 M43
V1X U F09 F11 G33
GB2 H2B2 GB7 707 312780
E24 D31 LH23 C1R 306026
There are allot of people that has this info here, But they could be busy.
7demon2 :wav:
don't know for sure but it is battery related :salute: Amp rating # :thumbup:
If someone knows, please post it here...I just don't have the info here for these....Thanks
Bryan
I found these on the web under fender tage info 71 dart.it does look like a battery or alternator #
F09 -
F10 -
F11 46 Amp Alternator (69), 50 Amp Alternator, 70 Amp Alternator (70-71)
F12 41 Amp Alternator
F13 60 Amp Alternator (69-71)
F14 -
F15 (65) 75 Amp Alternator (69-71)
F16 -
F17 Radio Suppressor Package ( 100 Amp Alternator, 114 Amp Alternator) (69-71)
F18 65 Amp HD Alternator
F19 -
F20 -
F21 Battery Dry Charged Less Acid Export Only
F22 46 A/H Battery with Green Caps, HD Battery Export (69-71)
F23 59 A/H 375 CCA Battery with Yellow Caps (69-71)
F24 325 CCA Battery
F25 70 A/H 440 CCA Battery with Red Caps (H.D.) (69-71)
F26 80 amp Battery (H.D.) (71)
F27 500 CCA Battery, Dual Horns Police Australia
F28 500 A/H Battery
Special order engine? 400 cu in 2 bbl? WEIRD!
Got this from a decoder that has both VIN and Fender tag decoding. Not sure where I saved it from
Sounds like an odd car, if so. Do you have it? Any evidence of a big block?
Also, on the build sheet template that I have, it says spec. engine in the F 0- slot.
I thought "E24" was the engine code? No, I do not have the car....it belongs to a friend in one of my other websites....
Bryan
Yes, it is a 225 car, but he mainly wants to know what the "FO9" stands for....
Bryan
