im looking for info on a quick release steering wheel hub for my 72 duster its really a tight squeeze into the seat over the roll cage ,what is the spline count and or any suggestions and part numbers thanks
You can easily use a GM one, that is what I did on my Cuda just be sure and match your steering wheel to the disconnect hub. Let me know if you want some pictures. I can look and see if I can find part numbers but there is a potential issue if my column does not match yours Rendering them invalid reference?im looking for info on a quick release steering wheel hub for my 72 duster its really a tight squeeze into the seat over the roll cage ,what is the spline count and or any suggestions and part numbers thanks
And you have to remember to always park car with wheels straight before you remove steering wheel. I use blue tape on mine as well for a 12 o clock reference. Holler if you need pix.im looking for info on a quick release steering wheel hub for my 72 duster its really a tight squeeze into the seat over the roll cage ,what is the spline count and or any suggestions and part numbers thanks
