Quick Tire question 28/9/15 MT
Dustedu2
Dixon
I keep seeing conflicting info, Help with question: I have 10" rims, will the MT 28/9/-15 fit the 10" rim width. And if so how does the height come out?
what kind of M/T tires? sure they will fit but the rim is wider then the tread it sounds. height of the tire? not sure. they all seem to be a little different.
not sure what tire your looking at..
http://www.summitracing.com/parts/MTT-3054/
Brand Mickey Thompson
Manufacturer's Part Number 3054
Part Type Tires
Product Line Mickey Thompson ET Drag Slicks
Summit Racing Part Number MTT-3054
UPC 787025030549
Tire Size 28 x 9.00-15
Wheel Diameter 15 in.
Sidewall Style Blackwall
Tire Construction Bias-ply
Directional No
Tire Diameter 27.30 in.
Section Width 10.80 in.
Tread Width 8.60 in.
Minimum Recommended Wheel Width 7.60 in.
Maximum Recommended Wheel Width 9.60 in.
Asymmetrical Tread Pattern No
DOT-Approved No
Tube Required Yes
Tire Compound L8
Quantity Sold individually.
Tool Transmission Lookup
Calculator Gear Ratio Calculator
That sounds like a very narrow tire for 10" wheels. Is there a particular reason you are looking at that size tire?
...........I run the M/T ET 28x9/15 slicks on 10 in rims.......dont forget that slicks are shorter than DOT tires........if i remember rite mine are approx 26.75 tall ........kim........
Well they are new and $125 for the pair. I have 26 in MT street radials and wanted to try a little taller tire.
I did not know that. They would be 3/4 taller than my 26". Just want taller to lower high speed RPM
