quickest et,s on an edelbrock carby
difference is the secondary air door.....AFB counterweighted, AVS spring loaded.....otherwise they should be pretty much identical. Did you compare the stock metering rods and jet sizes?
I think it´s true what blownhemi said. There should be a bigger Version like 950 cfm. At what rpm did you see this vacuum?
Michael
6000rpm
good thread and a great response,id be prepared to lose a tenth or 2,if you have a fast 02 sensor on your collecter the edelbrock should be easy to tune,thats what i plan on buying
Was searching for random knowledge and found this old post. Figured I would add to the random knowledge. 11.17 at 120 with a Edelbrock 800 thunder AVS.
