Racing slicks n wheels
z_daddy
z_daddy
Naples, Fl
Will 29 x 10.5 -15 Slicks fit on rear of 68 Plymouth Valiant not tubbed is O.E. 8.75 rearend the springs stock location also what rim width and back space will I need ??
Like what
I don`t have a valiant, but my guess would be to massage the heck out of the inner fender wells, the outer ones as much as possible w/o denting the outer fender, and offset spring hangars. 8" wheel maximum, w/ a perfect offset, and rolled outtter fender lips, w/ the front fender
reshaped to the inner fender contour(before paint). I have 295 65 15 draq radials on a 68 barracuda done this way. I am assuming the fenderwells are about the same on these two cars .. ????
reshaped to the inner fender contour(before paint). I have 295 65 15 draq radials on a 68 barracuda done this way. I am assuming the fenderwells are about the same on these two cars .. ????[/Well I’m going to mini tub and move springs inboard so this will work!!!
Never mind guys n gals I found the only Solutions :Well I’m going to mini tub and move springs inboard so this will work!!!
Run those on my sons 67 cuda without a problem.
