Anyone has any kind of experience with this product?
AJE Suspension MP-9602: Power Steering Rack Conversion Kit Mopar A-Body | JEGS
I saw that... but maybe someone has used and made any kind of modification on the original k member.. or another tubular brand...Says you need their K member too
Yeesh. I wouldnt try it. What have you got to gain? See GregDart's extensive thread on the Pinto rack in the Dart.
Home built rack and pinion+ coilover build.
He fabbed it from scratch but is only suitable for a drag car as there is no ackerman angles. I thought about the same thing putting a Neon rack (rear steer) where the center link is and just fabbing the rod ends so everything stays in place and running a clearanced pan. Never got off the drawing board when I saw the steering shaft angle and the 2 U-joints Id have to run.
