w2 stroker
- Joined
- Mar 14, 2006
- Messages
- 62
- Reaction score
- 37
what upper and lower hose do I use to fit a 2004 truck motor in a 68 dart?
thanks guys for the kind wordsIDK either - but DAMN that is cool!!!![]()
We tap the top of the timing cover/WP in ours...that way you can use a simple AN fitting/hose end for the heater hoses. They can route right under the intake manifold on the car setup...helps hide it a little better.thanks guys for the kind wordsmy greatest fear is that when I add the ac and heater hoses plus the last wiring that it will get fugly quick lol
Did you do the hidden coil packs yourself or is that a kit. If you did them would you Mind sharing how and what you usedwhat upper and lower hose do I use to fit a 2004 truck motor in a 68 dart?
Agreed, that is super sexy. I was not creative enough to figure out what to do with them On mine. I would love to hear the response to this question. I love this thread! I always learn or see something Super cool.Did you do the hidden coil packs yourself or is that a kit. If you did them would you Mind sharing how and what you used
for radiator hoses i ended up using one of the chrome flexible style for the upper and a 318 abody lower that i had to shorten slightly. the coil mount i made myself. i used 1/8" aluminum plate. i forget the dimensions but hade a local sheet metal shop do a couple simple bends. basically 6" wide with a 45* bend of 1/2" to hold it up off the valley. then cut holes for the coil packs and taped the plate for the factory bolts to attach.Agreed, that is super sexy. I was not creative enough to figure out what to do with them On mine. I would love to hear the response to this question. I love this thread! I always learn or see something Super cool.
