Rag joint
73stroked duster
streamwood
just picked up a 72 duster. Has a lot of play in steering. Does this year have a rag joint on the steering shaft. I do not see one on my car but seems there might be a place for it.
No rag joint on Mopars. That's a GM thing. The coupler at the steering box, on the end of the steering column shaft may need to be rebuilt. You can also replace it with a u joint style coupler.
It could just be a worm steering component like a tie rod, pitman arm or idler arm.
You have the car. Why not look at it?
