rally dash question
Mopar Interiors
  1. downsr
    downsr FABO Gold Member FABO Gold Member
    873
    466
    Dec 17, 2011
    waverly ohio
    Local Time:
    11:34 AM
    Anyone tell me the differences in a late 60's barracuda rally dash and a 70 duster rally dash
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    52,964
    17956
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:34 AM
    Some people have different ideas of what a ralley dash is. This thread could get interesting.
    I've only had 67 & 68 Basrracudas, no Dusters, so I can't tell what the comparison is.
  3. krazykuda
    52,964
    17956
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:34 AM
    I believe that both ralley dashes have the round "bullet" connector for the wiring to the dash. Versus the flat rectangular connector for the standard dash comparing my son's 71 Valiant regular dash to the ralley dash wiring harness.
  4. 78kitcar
    78kitcar Well-Known Member
    1,113
    13
    Mar 9, 2008
    cleveland
    Local Time:
    11:34 AM
    I remember reading something about the way the numbers on the speedo and tach were positioned. Don't know for sure
  5. krazykuda
    52,964
    17956
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:34 AM
    I always thought that the ralley gauges had the 150 MPH speedo, but someone contradicted that in a different thread...
  6. doug 371
    doug 371 Well-Known Member
    1,944
    197
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    5:34 PM
    the steel dash frame has the key in it in 69 back
  7. doug 371
    1,944
    197
    May 29, 2004
    Regina, SK CANADA
    Local Time:
    5:34 PM
    70 duster will have 150 speedo...barracuda can have 120 or 150 speedo
  8. dusterdan
    dusterdan Sublime Member
    1,173
    20
    Dec 23, 2008
    La Mirada, CA
    Local Time:
    9:34 AM
    To my knowledge, 70/71 Duster/Demon 340's had a 150mph speedo and an optional tach. No performance indicator was offered to my knowledge. With the barracudas, the speedo was 120 (earlier models) or 150 and a tach or performance indicator was optional. I could be wrong. Here are pictures comparing the two side by side, notice the finish differences (silver vs woodgrain). For a fact, both of the dash frames are identical EXCEPT Duster's/Demon's had the ignition in the steering column whereas barracudas had them in the dash frame themselves. Also, thumbwheel radios were avalible in both models depending on the year.....
  9. mvh
    mvh FABO Gold Member FABO Gold Member
    1,525
    272
    Dec 17, 2007
    Menlo Park, CA
    Local Time:
    9:34 AM
    "Rally" dashes are the ones with the two large circular gauges (speedo left, 4-way gauge right), and a smaller circular one in the center (tach, vac gauge, clock or blank). This dash bezel was on ALL 67-69 Barracudas, and was not used on Valiants or Darts. It was revived for use on Dusters. There are several different versions of the bezel: 1967 had regular knobs on the radio, 68 and 69 had thumbwheels, and AC dashes were different in the heater control area. The gauge faces used different typefaces for the numerals in different years.
    I personally don't know if Dusters had thumbwheel radios or knob radios. But I believe they were somehow different from Barracuda bezels, if only in some arcane detail like the lettering around the heater controls. They can be swapped for each other assuming you have the right type of radio, and with or w/o AC.
  10. krazykuda
    52,964
    17956
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:34 AM
    Yes, but I don't think that would effect the dash gauge cluster as the key is mounted below the cluster on the late 60's stuff and in the steering column on the early 70's. None of them interfere with the dash gauge panel. But it is a valid difference between those years.
  11. cudascott
    cudascott Now I have a Hemi
    1,670
    544
    Jan 11, 2012
    TN
    Local Time:
    12:34 PM
    Differences are radio openings and lettering on the speedo and tachometers
    And temp controls
    Other that that they are the same. On barracudas the 150 speedo was an option
    for 67' thru 69'
  12. Rocky_JS
    Rocky_JS 'cuda
    4,198
    155
    Feb 27, 2011
    Highland Maryland
    Local Time:
    9:34 AM
    not entirely , wood grain aside...
    67-9 barracuda had hazard switch in the dash duster/dart did not.
    all years offered a 150 speedo, was std on duster/dart
    67 only had screw on speedo cable
    67-8 had speedo numbers aligned with the needle
    69 up including duster dart had the speedo numbers up and down.
    67 and 71 had post radio
    68-70 had thumb-wheel tadio
    67 heater control is one year
    Tachometer avail all years 67 was a one year only tach face
    clock was avail 68 up -
    vacuum gauge was avail 67-9
  13. downsr
    873
    466
    Dec 17, 2011
    waverly ohio
    Local Time:
    11:34 AM
    Would the lettering around the heater controls be the same on both dashs without air?I know the barracuda dash does have a flasher control on left side of dash that the duster dies not.Thanks for all your replies
  14. RedFish
    RedFish Well-Known Member
    24,204
    2817
    Sep 5, 2007
    Local Time:
    11:34 AM
    67 inst' housing and bezel are different at climate controller.
    68 and up are the same.
  15. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    29,024
    9119
    Aug 28, 2009
    Wasting time here
    Local Time:
    11:34 AM
    I think all the differences have been covered.
  16. 1970Duster
    1970Duster Well-Known Member
    6,677
    88
    May 30, 2010
    Local Time:
    9:34 AM
  17. Zak
    Zak Active Member
    39
    1
    Jun 3, 2010
    Valdosta, Georgia
    Local Time:
    12:34 PM
    the harness is different for both.
