RB Valley plates
william parker
North Dakota
Anyone know for certain which valley plate will work on a 440 with Trick flow 270's? TF plates are backordered.
I can’t imagine why an Indy cover wouldn’t work.
Same basic thing as the TF cover.
Get the one with the removable panel.
My solid plates were designed to work with TF 270 heads.
Valley Plates | AR Engineering
They'll also work with the TF 240 heads if you use the batwings to seal off the valley. With 270 or Indy heads you don't need the batwings since the heads sit on top of the edge of the valley. Just run a bead of RTV on the edge of the valley and then bolt the head down and you're good to go.
