Hi guy another problem ( or so ).
Because of the markes on the carrier i was supposing that the pinon was too far, and maybe removed the shim on the pinion.
The other pinion ( the 5:1) i removed had no shim at all.
The 3.21 pinion had 1 shim but because of the marks i made a try and removed the shim. But now, i still have play even i torque at 210 / 220 newton ( hard for me to go more than that ! )
I am in the wrong way and do i have to stop here not to try to torque too much ? Or do i have to torque really high in order to eliminate this play ?
What is strange for me is that when i put this pinion the first time ( with the older crush sleeve i admit ) everything was fine and i was torquing down normaly without excessive force and i was able to get 20 inch/lbs of preload easily.
