rear courtesy floor lights
Can you post a picture of these lights? I don't think my car has them. I'd like to have rear courtesy lights.
That fixture should be snapped into the panel like the tag light fixtures in step bumpers. Infact those little round tag light fixtures are nearly identical
What year car?
I have a 64 and changed both burned out bulbs by gently prying the "eyeballs" out of the panels.
thanks guys - I'll try prying 'em out slow...will try to get a pic.
it does twist off- have to pop it out of the mounting hole first- then it can be pried apart in two pieces .replaced bulb - good to go.
no seat removal needed - they will pry out of the hole - then you pry the fixture apart. no big deal.
They are tight, though, if you haven't pulled them before. I thought I was going to break something. But once they have been out once, they're a cinch.
yes. Like to see your blue convertible close up. I want to post some pics of my banana yellow (viper yellow actually) '68 barracuda conv. but am hamstrung by weather right now. I am impressed with volume of expertise on this site ...decent guys... and gals no doubt!
