HawaiiDuster
Mopar still has them, give John Cambridge a call. They're about $40 a set and come in 7", 8", or 9"lengths. I picked up a couple of the 8" sets last month.
GotDart said:I am still looking for some myself. I have seen used ones on eBay before, but always for more than they are worth. I have not found a source for new ones.Are u-bolts hard to find?
BOSS VEGA V8 said:limited slip is what chrysler calls "sure grip", a non posi is called" open"
limited slip means that the other wheel will slip to a limit,where as a non limited slip will slip all the time,causing a "one tire frier"
so it is an open rear right? to run that rear you ar going to need some custom rims or something from a front wheel drive.....i dont think its that great of a deal....lot less work to use a jeep 8.25..... just have to change the spring perches,whick you can buy pretty cheap,just mesure yours and weld the new ones in the correct place...
