Methuselah Member Joined Sep 21, 2010 Messages 16 Reaction score 0 Location Clayton Mar 19, 2013 #1 I have an 8.25" rear end, with 2:45/1 gears. I want to upgrade to 3:73 gears. Will the stock gear housing accept this or does it require modifications?
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,426 Reaction score 13,820 Location Berlin,N.J. 08009 Mar 19, 2013 #2 i believe that the 2.45 housing needs modification. hopefully someone that knows for sure will chime in..
2 Darts A-body Addicted Joined Mar 28, 2008 Messages 3,428 Reaction score 278 Location Usually in a house Mar 19, 2013 #3 I'd suggest calling someone like Drivetrain.Com or Randy's Ring and Pinion. Sites below have the toll free number listed. http://www.drivetrain.com/parts_catalog/ring_and_pinions/chrysler_8.25_ring_and_pinion_sets.html http://www.ringpinion.com/b2c/Parts...odelID=216&Side=Rear&DriveType=RWD&DiffID=102
Inertia Well-Known Member Joined Feb 4, 2011 Messages 5,897 Reaction score 3,359 Location Victoria B.C. Canada Mar 19, 2013 #4 This was response to my same question a coupla weeks ago.. Quote: Originally Posted by Saetun 2.76 and numerically higher use the same carrier. yep. the 2.45 and i think 2.5x or 2.6x only use one carrier, the 2.76 and up use another
Supershafts Well-Known Member Joined May 12, 2010 Messages 1,413 Reaction score 68 Location Long Island, N.Y. Mar 20, 2013 #5 You need a new carrier to go to 3.73 If you had 2.71 or better then you would only need the gears and bearings. Now you get to choose a carrier too
