ACME SS
I have a 71 Demon with tail light issues. I do have a schematic however I'm not positive the lights worked properly before I noticed the turn indicators not working the other day. And what I mean by that is I never checked them with the brakes on.
Without frying my melon with the schematic that is split into 2 sheets, I thought perhaps someone could tell me what "normal" is so I can have a bit of a head start. Here is what my current conditions are, I'm curious what is correct and what is wrong? Thanks in advance
Headlights ON---Tail lights on dim (seems correct)
Headlights ON, Brake on---Brake light comes on (seems correct)
Headlights OFF --Nothing (correct)
Headlights OFF, Emergency Flashers ON---Flashers flash bright like brake filament
Headlights OFF, Emergency Flashers ON, Brake ON---same as previous scenario, no way to know brakes are on (seems suspicious, wondering if wrong filaments are being energized for emergency and signals?)
Turn Signals Left or Right--Stopped working although a few times one or the other will blink once or twice which is obviously wrong
Turn Signals (not working) and brake is applied---The brake light on the side the signal is on goes out and there is no signal in rear or front (I'm thinking there is a short to ground somewhere?)
Also, when the brake light is ON, BOTH filaments light up and when I remove the socket from touching ground, the lower filament goes out and the taller filament stays lit but dims down.
I know a lot of this is wrong but it would be very helpful to know how it should be. I have run a separate ground to the light housing so I don't think a lack of ground is an issue. I know everyone likes a picture but there isn't much to photograph on this one.
