rear shock nuts and washers
trudysduster
Corinth, Ky.
Hey, I am looking again for parts for my sons 73 Dart Sport. I need the nuts and beveled washers that go on the rear shocks. I believe there are 4 washers and 2 nuts per shock. Does anyone have these. Shipped to 41035. Thanks,Bill
UPDATE: all I need now are 4 of the washers. these have the washers on the studs on the top and bottom and I am going to get the nuts at a parts house tomorrow. I need the outer washers for the upper and lower shock mount.
Can easily be made with large diameter 1/2 inch washers. Take a 3/8 diameter bolt washers and nut and try and pull the 1/2 inch washer through a pipe or socket the same outside diameter until it conical's the washer to your needs.
You should be able to buy them new from the dealer. The last time I did I ordered them for a 93 2WD pick-up, 1500. The part numbers are different inner washer and outer washer. The inner washer has a larger hole.
oldman, how much shipped to zip 41035. I need 4 of them. the outer ones. they are 1 3/8 " in diameter and have a 1/2" hole in them. If you have 4 factory ones with these measurements, I want them. let me know, Bill I have ran out enough gas to pay for them. The dealer up here is as useless as tits on a boar hog. I have tried every parts house close. I can get them out of N.J. but if I can get them here, I would rather. let me know and thanks,Bill
Money sent for the washers Steve. Many thanks. search is over. what a way to start the New Year. woo hoo
