Dor-Dor68!
Hey Everyone,
Still gathering, but progressing on gathering all the parts for a front brakes, steering and suspension upgrade, but wanted to ask about the rear suspension.
Since im swapping everything in the front...im also thinking of upgrading the rear. Ive looked into getting a leaf spring relocation kit from USCT and welding it on there vs. The Doctordiff's offset shackles. But please let me know what your thoughts are. hopefully I can get a little wider tire on the rear with the relocation kit and not affecting any of the goals. I would like to put a 18x10 wheel in the rear.
So ive checked out the mopar performance super stock springs(3200lbs), but would like to hear from anyone thats using them or even the Hotchkis leaf springs with a 1" drop, and also the Calvert mono leafs, But any suggestions would be appreciated. The rear end will be a swapped to a Ford 8.8 with 373s.
The only thing is that im looking for a great stance on the car, aggressive, but not too low either. The Darts goal is to be a daily driver, canyon carver and hopefully some autoX in the near future.
For the relocation kit im looking at the USCT kit, and also considering adding the Calvert's leaf spring sliders....but not sure if they'll be a good fit with the relocation kit. Any other suggestions on the slider boxes???
I'll attach a picture of how the Dart currently sits and again I'll appreciate all and any suggestions, info or ideas....and or other parts you all recommend or suggest.
Hope everyone is doing great and thank you for your time.
