Rebuilding the front suspension
HemiPar
Kentucky
OK, I have my "new" BBP front suspension from a 74ish Dart to replace mine on my 71. I am getting it all cleaned up, primed and painted, and will be installing new bushings. I don't have a factory service manual and was wondering if some one has a diagram of the front. I wanna make sure I get all the needed bushings, washers nuts bolts and what-nots. I really don't wanna forget to put something on and the front end fall off while driving. Thanks in advanced for all help with this.
It does feel great to be putting something back on the car.
Did this swap on the Demon. The only real difference from a fastener standpoint is the routing of the anti-sway bar. If you're not running the bar, it's the same as the older unit. The older bars ran forward of the K-frame whereas the newer bar runs through it. The bar attachment to the K-frame is a little different as a result.
Thanks Demon. I am not putting a bar on as of now. May change in a few years. I will be using the 71 LCA and 74 everything else. The question i had is for the brakes in general. I wanna make sure I get all the nuts, bolts washers and screws that are needed to do the swap. And the torque specs so it don't fall apart while driving.
Also so I know what to order. Some net sites will not "make a package" with mixed years. Plus my budget will only allow me to get one side at a time.
Thanks for the reply thou. I figured that more would say something bout it. I guess to tired of answering front suspension questions.
