fishy68
Tyr Fryr's Inc.
Trying to help a buddy repair his wiring harness for his 1990 Dodge Ram and it has a multi fusible link arrangement (5 total all molded into one outlet) and one is burned up. I know a lot about wiring but I don't know why they use fusible links instead of fuses. Can anybody tell me if a fuse (standard or slow blow type) is an acceptable substitute for the fusible link? The wire leading to and from the fusible links are 10 gauge. I know 10 gauge wire is rated at 30 amps continuous so would a 30 amp fuse be ok to use?
