Replacment Gas Tank?
stop the beast
Arizona
Hi All,
I'm looking to replace my FSU, tank and tank straps in my '66 and I'm wondering if you can recommended where to get the best parts for the price.
And do you all have any recommendations for coating the tank as well? From what I've seen most of them come bare steel and that's no good. I've also seen a huge price disparity from various vendors - but the tanks all look the same.
Thanks a lot!
i got my tank from vansauto.com. vey nice and quick shipping. i lined the inside with blue lightening gas tank liner...
Here is a link to the mob that I dealt with earlier this year.
http://cgi.ebay.com/ebaymotors/NEW-...r_Truck_Parts_Accessories&hash=item2eb6ce96e2
(that's an Ebay feed)
They were extremely helpful (bear in mind that I am buying from here in Australia). This is a Canadian made top quality tank with a full warranty. Ask the other sellers what warranty they give (it's mostly just 3 months) and also I have read about fit problems for the cheap tanks. I am wrapped in mine, and like I said the bloke is fairdinkum!
How was it putting that liner into the tank? Is it low viscosity? I was looking at the POR-15 product for the lining inside. I was thinking about simple epoxy chassis paint on the exterior.
it was okay....i washed it out with acetone, let it air dry for a little while, then taped up the opening and pour in the blue lightening, (which is actually bright green) LOL, sloshed it around for about 10 minutes turning the tank upside down at all angles, then drained it out and let it dry....it has the viscosity off....5w30 engine oil..if you will...
Rock auto parts, cheap, they have the sending units also I do believe. I used 66 Barracuda since I didn't know what you had
http://www.rockauto.com/
SPECTRA PREMIUM Part # CR11A $181
SPECTRA PREMIUM Part # FG69B More Information About this Part Includes Fuel Sender, Float and Strainer (Fuel Pump Not Included)
3/8" Outlet; w/ Fuel Return $65.79
Straps
SPECTRA PREMIUM Part # ST95 More Information About this Part Set $15.53
I got everything from them for my 67 cuda. Spectra is made in Canada if im not mistaken.
Hey Gary,
How's this tank holding up? I say it's nickel coated for corrosion resistnce but I'm leaning toward covering it up anyhow. What do you think?
Thanks.
Thanks for all the feedback! I ended up ordering everything from Van's in WI. I'm probabaly not going to pre-treat the inside of the tank (I'll let someone else worry about that in another 40-years) and I'm going to clear coat the exterior because I love that bright metal look that mullinax95 was sporting.
