Reverse Indicator Light (under dash)
RIBOATSERVICES
RHODE ISLAND
Hi,
I`m restoring a 73 340 Duster 4spd and was wondering if the reverse indicator light was used (or an option) in 73 or just earlier years ? Figured someone here would know. Thanks
factory 4-speed cars had it, factory 3 speed manual did not
Thanks, after 42 years of people drilling holes in the dash do you know where it was located under the dash? I`m guessing just left of the ashtray.
It was not under the dash on my 73 Duster. There is a 3/4 inch hole cut into the OEM dash. We changed dashes, because the PO had cut the OE dash for a radio, and had to make a new hole in the replacement dash. The wiring for the lamp goes through the firewall with a grommet. I am trying to find some pictures of the correct spot for this.
I added one to my 69 Dart and tied in the light to the harness under the left kick panel going to the rear lights. Not correct but it works.
