Ironracer
Gearhead
Hey everyone, hope Y'all are doing g as well as can be. I just replaced my 10 year old, shot poly bushings with new rubber ( proforged, w/ pins) and the, (after calling Moog) now " obsolete " grrr, problem solving strut bushings. Tighten em up just snug,and drove about 100' to a more level driveway to set Ride height. When putting the torsion bars back in I left the lca hang in their lowest position. Then turn the screws in until they contacted the Adjusters about 9 turns each side. That was before I moved her. Drove her over there turn them in where is the top (lowest part) of nut is flush w bottom of arm. Looked okay, send Rover back into my carport the damn fienders are sitting on top of the tires,Again! This ain't the first time I've done this,but what the hell is going on? Did I screw it up? I'm already pissed off about this thing as I had a friend of mine( used to be a good machinist and mechanic) and a good welder. Sent home Jim's video on that... but when he welded the braces on the lower control arm, i can move the pins about a half an inch at the end of their travel, the further side from arm.( they slide back and forth in the arm in the socket about 1/8 inch each Direction) if I got to take the damn things back off or something I will cut through all those welds n take em somewhere else. I haven't drove my car in about 2 months... anyway I'm trying to figure out if I did something that screwed up the ride height (s)
