Ride Height
gipperco
Turner, Oregon
I was wondering if anyone would be able to give some pointers as to the easiest way to adjust the RIDE HEIGHT on a 74 Dart. It was a Slant 6 car and now has a 318 in it and it needs to be adjusted sot hat it sets better. It has SS Springs on the back and it is being set up for the track.
i,ve had the best luck jack up front from frame then crank in on the t bar bolt / both side then lower off the jacks then move car back and forth then recheck till you get it were you want / you can use a tape mesure to make sure it,s even. off of the lower part of the fender. hope that helps. als
I would just try some paint thinner to try and get the pink off the door jams... oh wait, you were looking for adjusting ride height...
You trying to adjust the rear down or the front up?
